Cooling Performance
Our micro-ATX test kit would not fit inside the Precision PS09 due to CPU cooler limitations, so we've dropped down to the mini-ITX test gear for thermal testing and comparisons.
Our mini-ITX test kit includes:
- CPU: Intel Core i5-2500K overclocked to 4.3GHz using a vcore of 1.3V.
    - Graphics card: GeForce GTX 570 1.3GB
    - Motherboard: Asus P8Z77-I Deluxe
    - RAM: 4GB Kingston DDR3 1600MHz memory
    - PSU: Enermax Eco 82+ 620W PSU
   - CPU cooler: Zalman CNPS 8900 low-profile cooler
While some cases can house larger coolers, for the results to be comparable, we needed to pick a cooler that was going to fit in as many cases as possible. We therefore opted for a low-profile cooler. This will give a good idea of how well the case is able to remove heat from the system - our primary concern in case testing - although you can probably expect to achieve better results by using a larger cooler if the case in question supports it.
The graphics card fan was locked at 70 per cent speed and the system was loaded using Prime95 and Unigine's Heaven benchmark. We used Realtemp and GPU-Z to monitor the temperatures, taking the maximum values when the readings had plateaued.
        SilverStone Raven RVZ01
        Silverstone Sugo SG08 (max speed)
        BitFenix Prodigy
        Silverstone Sugo SG08 (min speed)
        Silverstone FT03-Mini
        Fractal Design Node 304 (max speed)
        Cooler Master Elite 130 Advanced
        Lian Li PC-TU200
        Corsair Obsidian 250D
        Lian Li PC-V360
        Lian Li Lian Li PC-Q28
        In-Win 901 (Zalman ZM-F2 92mm + Noctua NF-F12 120mm)
        Lian Li PC-V358
        EVGA Hadron Air
        BitFenix Phenom
        Cooler Master Elite 120 Advanced
        Antec ISK600
        Fractal Design Node 304 (min speed)
        SilverStone Precision PS09
        In-Win 901 (no fans)
          20
          30
          40
          50
          60
          70
          80
    °C, lower is better
        BitFenix Prodigy
        Antec ISK600
        Lian Li PC-V360
        Lian Li PC-V358
        EVGA Hadron Air
        BitFenix Phenom
        Lian Li PC-Q28
        Lian Li PC-TU200
          20
          30
          40
          50
          60
          70
          80
    °C, lower is better
